They're good for vacation homes where they get turned on and off frequently.Would a 30 amp 2 pole toggle switch be an acceptable means for a residential water heater?
50 gal / 4500 watt
I've used 30 amp AC disconnects in the past but am looking for a "cleaner" flush type means.
4" square box w/ mud ring and FMC out through drywall into tank.
Thanks
A/C disconnects are generally low cost but I haven't been finding any that low.A/C disconnect costs about $7
30 amp switch, 1900 box, and raised cover is gonna put you close to fifty bucks.
Good point.It would be acceptable./
For a real "clean" look, use a breaker lock instead of a disconnect, 422.31(B)
