AV ELECTRIC
I see ev chargers like Ford that can require up to 80 amps but can be dialed down on a type of internal dip switch on the circuit board for lowered amperage charging rates . I have read that for this 80 amp charger you can dial down to a lower ampacity and the circuit supply can be rated for that dialed down ampacity . To me that makes no sense as what stops one from dialing it back up to a maximum charge of 80 amps . I thought a devices overload protection is based on it's maximum ampacity . I also see this plugging into a 120 volt circuit . You can dial it in for a 15 amp circuit or 20 and the charger doesn't differentiate from either .
