Horst174659
- Europe
- private
Hello,
I am planning to install a PV system and have two questions regarding this:
First: I can choose between 2 electricians which charge the same amount, but use different panel suppliers. One uses "Bauer Solar" (a german manufacturer) and the second uses "SunRise".
Which of these manufacturers are known to be good or better than the other?
Second: It could be an option to install an additional layer of panels horizontally (the other would be mounted vertically) and those would be about 8 Inch / 20 cm over the edge of the roof. The wind in this area is moderate but not too strong and the panels would face south. Is it advisable to do so?
I appreciate any help and thank you in advance.
Best regards!
Best regards!
