wwhitney
- Berkeley, CA
- Retired
Are you actually proposing that if I (a) dig a trench of sufficient depth, install the wiring, cover it up with the spoils, and then add 2" of concrete on top, that complies, while if I (b) have overexcavated a large area, install the wiring, add the necessary depth of fill over the large area, and then add 2" of concrete, that doesn't? While I agree that's a literalist reading, it's too nonsensical even for me.So if it is not in a trench you can't use that line.
Regardless, if it's being installed under an existing driveway from above, then that will likely involve cutting a trench through the driveway and it will end up in a trench.
Cheers, Wayne
