fandi
- Los Angeles
- Electrical Engineer
Hello All,
If a PV inverter connects to the load side of a main service panel (MSP) without a PV breaker at the MSP (basically it's a tap at the MSP), is it a violation of which of the following code sections:
- 705.12(B)(1) Dedicated Overcurrent and Disconnect.
- 705.20 Disconnecting Means, Sources.
- 705.21 Disconnecting Means, Equipment.
- 705.22 Disconnect Device.
- 705.23 Interactive System Disconnecting Means.
- 705.30 Overcurrent Protection.
Note: There's a separate fusible disconnect switch between the PV inverter and the MSP.
Thank you.
Thank you.
