The place on the bender where you line up put the mark on the raceway is arbitrary. You can build a bender and make the line up mark anywhere you want. You would just need to adjust the deduction based on where you decide to have the line up point.I think what's throwing me off is a hand bender the arrow is the take up whereas the electric bender the front of the shoe is the take up
Yes I figured it out it was a little confusing at first but yeah you can use the arrow as a benchmark or the front of a shoe as a benchmark the arrow on a hand Bender is start of bendThe place on the bender where you line up put the mark on the raceway is arbitrary. You can build a bender and make the line up mark anywhere you want. You would just need to adjust the deduction based on where you decide to have the line up point.
Thank you for everyone's help!Yes I figured it out it was a little confusing at first but yeah you can use the arrow as a benchmark or the front of a shoe as a benchmark the arrow on a hand Bender is start of bend
Exactly. Say that you decided to build your own 1" bender because you wanted a larger radius bend. You build it then you bend your first piece of conduit by starting the end of the pipe even with the end of the bender. You end up with a 15" elbow. That will be your deduction for elbows when aligning the mark on the pipe with the end of the bender. Now you decide that you want to use the arrow that you marked on the bender 3" back from the front edge. When bending using you arrow your deduction for an elbow is now 18" (15+3).Yes I figured it out it was a little confusing at first but yeah you can use the arrow as a benchmark or the front of a shoe as a benchmark the arrow on a hand Bender is start of bend
