mark32
- Currently in NJ
Hey guys,
A friend had a detached garage remodeled into a nicely finished hangout area for himself, complete with a split a/c system. Towards the end of the summer, the a/c compressor went bad, at least according to his a/c guy (Initially he thought a circuit board had went bad) He replaced the condensing unit and told my friend he should get some form of surge protection for it to hopefully avoid this issue again. Because the panel is flush mounted, I installed a surge breaker. This breaker only has a neutral lead coming off of it, and as the instructions say, just terminate it to the neutral bar. On the way home, it dawned on me that perhaps I should have landed that lead on the ground bar because, at least, there are two ground rods directly outside this structure. The feeder coming from the house (Four conductors) has an estimated length of 80'. So, should I leave this neutral lead connected to an 80' neutral conductor, or would it be better for the sake of his equipment (At the detached structure) that I terminate it to the GEC/ground rods via the panel's ground bar ?
