Sparky2791
- Northeast, PA
- Electrical Design
Have a stand alone fire water tank which will have (2) 10kW heaters inside the tank. Each with separate controls no disconnecting means provided with the tank heaters by the manufacturer. This tank will be sitting about 15' away from the buildings electric room. I assume each of these heaters to require a disconnect switch at the tank. What NEC code section would justify this requirement for this type of situation.
Thanks for the replies!
