Hello,
I am reading a statement note from the answer sheet 8 10, question 47. It states...
Don’t confuse distance (D) with length (L). This formula give you distance between two points, not length of conductors in the circuit.
As I would understand this statement... if D=149 then this is as the crow flies from point A to point B. In practice, I would not want the wire between the two point to be more than 149 feet. If I had vertical runs of 5 ft on both sides then the distance between the two points would be 139 feet. Making the wire length still not more than 149 feet.
Can anyone provide any further explanation that I may be missing?
