3PH Breaker feeds 3 single phase loads
wbdvt
Rutland, VT, USA
Electrical Engineer, PE
Hello,
I have encountered a 3 phase breaker with each pole feeding a separate load. In this case, each breaker pole feds a single phase heater. I have not been able to find anything in the code addressing this. Is this code compliant? Is there a code section that addresses this?
TIA
Is there a shared neutral between the circuits? This is a typical multiwire branch circuit
He mentioned each pole fed a heater so a neutral would have to be involved.
JAP>
