New Romex Outer Jacket
Yes, it's very frustrating after using Romex brand for 20 years. I started a thread "Romex brand 14/2 and Ginsu utility blades" a few weeks ago. I don't know if anyone remembers the Ginsu knife commercials about cutting through a shoe. Well I need some Ginsu utility blades. I haven't seen a change in 14/3 or 12/2 YET.
Anyone know why they changed it? Is it a new listing requirement of some sort?
I get it cheaper by about 30 bucks a roll from the supply house than Cerro from HD so I'm OK with it still. I get the 14 2 from republic and they're comparable in ease to work with so no complaints from me. In remodels I deal with the old black or white sheath with a yellow string in it and those must have been real slow to work with.
By the way, do not do a search for "kline strippers" with safe search turned off.
That being said, these kline strippers are a life saver with this new hard jacket. I measure the wire to the box, clip it with the end, then stick it in the box and yank the jacket right off.
The end will only cut the jacket on 12/2 and 14/2. It's very handy.Screenshot_20221025-182103~2.png
With the thicker sheath I was worried about knicking the conductors inside using the NM strippers.
I've tested it, cut the jacket 5 times or so and slid the pieces off. The insulation was not damaged.
I figure it's no more risky than trying to cut it with a blade. Been doing it for a couple of weeks now and I endorse it.
Just cut it at a perpendicular angle.
Plus side, It does seem it would be less likely to nick from pulls in joists or other edges. Maybe less rodent damage as a result?
I've been using the southwire nm stripper without nicking the conductors on that new southwire. Maybe the intent of making the sheathing tougher, sell more strippers? It works nice on the UF cable, that was always a pib to strip.
Still not sure I like the tougher sheath though. If the same compound will be used on the 14/3 or 12/3 will have to buy their 3 wire stripper too. Master plan?
