Irving LaRue
- Warrenton, Virginia
- Electrician Apprentice
A customer has backsplash tile in his kitchen and would like to have an overhead sink light switch and a garbage disposal switch installed next to the sink. I would need to cut out a hole in the tile to fit a 2 gang box.
What do you recommend to cut holes in tile that’s mounted on a wall? I’ve seen tons online regarding cutting holes in tile before you mount it, but not much for after.
Also, what kind of box would you use? I normally use blue old work boxes when I’m cutting into drywall. I’m not sure what to use in this situation because of the added thickness of the tile. The wall is an exterior wall with brick if that makes a difference.
