Question.meo
- Monticello, MN
- Electrician
Project involves a step up open delta 240V 3ph primary voltage to on a delta primary trans with a secondary wye 480V 3ph trans feeding a 3ph 480V machine. The trans came with a bonded sec wye connection. When energized (load in at sec. Turnrned off) the trans was extremely loud and vibrating. I ran across this many years ago on another project and had remove the sec. Neutral bonding jumper from the case of the trans. This solved the problem. However, I have a question on a possible fault current at the machine and it's path to to the primary 30deg. Phase shift main service grounded system.
