andyselec@aol.com
- durham,nc
- Electrical contractor
I haven't wired a home in years. Last time I did we were still running TV and phone wires do people still put them in or do you just run a couple of cat 5 wires for wifi?
If I were building a new home I would run at least a Cat6 and an RG6 to every room that may end up with a computer and/or a TV. The best thing for future proofing would be an empty raceway to each room. With the quality of wireless today that might be overkill.
You're correct but I'm old school and a lot of that depends on the quality of the wireless. I have Fios TV which can operate wirelessly between all of the set top boxes. Truth is it never worked well so I ended up running a RG6 to each STB location. Same thing with streaming. A mesh system would help but even then the wireless bandwidth is limited. I think that the average home buyer wouldn't bother with much hardwired equipment but it is superior to WiFi.Of course with smart TV's there is no need for cable as a roku stick will usually do it all. In the past 15 years or so we handed that part of the job over to the alarm companies. Let them handle the phones, cable, alarms etc.
I think that would be the gold standard for installations. It would allow the vendor to pull in whatever wire or fiber that they need to operate their system and only to the points where the customer needed them.I don't think anybody knows what's going to happen down the road. I think an empty pipe run to each room from some central location makes sense along with phone wires, cat6, coax to places where you know you're going to need it.
I'm a big fan of the empty pipe approach. I daresay it's safe to forecast that telecom "standards" will change five or ten times over the life of a house.I don't think anybody knows what's going to happen down the road. I think an empty pipe run to each room ...
makes as much sense as anything.So run it all back to where? Low voltage panel next to main panel? Mechanical room if there is one?
If there is a crawl space probably easiest thing to do would be to stub conduits from each room into crawl. Then have a bigger conduit up to the "central" spot.
I discussed with homeowner and realized I need to run a WIFI network (I knew this one already)
I've seen that over and over.Unfortunately, that's all homeowners know is WiFi. You don't need wiring anymore, you know
The customer will be better off in the long run in some cases if they have hard wiring but a lot of people get by with Wi-Fi and never miss the hardwiring. In the end it's what they're willing to pay for.Unfortunately, that's all homeowners know is WiFi. You don't need wiring anymore, you know. If that's their attitude let them get it from the cable company or some IT dude.
-Hal
