shockking
- Sacramento, CA
- engineer
We have two transformers, a main transformer and a backup transformer. Each transformer has it's own utility connection on the primary side. Both transformers have CT's for metering on both the primary and secondary sides, so four sets of CT's total. One set, the CT's on the primary side of the backup transformer, are backwards.
The facility is operating under normal conditions. All power is coming through the main transformer. An isolating switch on the secondary side of the backup transformer is open. The backup transformer is on an open circuit and sees zero current. However, there is still voltage from the utility on the primary side.
In this case, is it safe to disconnect and flip-flop the CT leads at the meter?
