I'm a bit concerned. I'm replacing some wall switches and outlets in my home and have noticed one location is delivering two circuits, breakers at 15A each, over one 14/3 bundle. I suspect this is both well outside any code (ever), as well as exceptionally unsafe. That said, I'm certainly not a certified electrician. What I see suggests that sharing a single neutral and ground in this way means:
Question #2: if I read code correctly, I can't run a single #14 THHN through an attic or basement ceiling to deliver the additional neutral unless I add conduit. If true, the simplest answer seems to run a new 14/2 to support one of those 15 breakers. (Thankfully, wiring is independent from there on). Correct? Any better ideas?
Question #3: House was built in 2004 if it matters, by a well-respected GC who's fairly principled. Wired by an electrical company that I thought was using certified electricians, but this wasn't an accident. It was wired this way intentionally. Any idea what they were thinking?
Thanks for sharing guys!
Dan
- There is potential for 30 amps on the #14 neutral, well over its rated, or even safe, capability. Fire risk I assume.
- Side Story: My wife has always claimed her vacuum doesn't work right plugged into the affected outlets. Guess I know why now.
- The possibility that somebody could get shocked. Turn off one of those breakers and it would seem safe, but not be. The neutral would still be "hot" from the other breaker!
Dan
