sparkync
- North Carolina
I went on a service call today about a breaker tripping. Lady had a microwave and toaster oven that had tripped the breaker. I took the panel cover off and amped the circuit she thought it was. I had her to run the toaster oven and microwave so I could see how many amps it was pulling. It was pulling 14.3 amps on a 20 amp breaker. Obviously it wouldn't take much to trip it. Refrigerator and washer was on the circuit also. Again, it's obvious why the breaker would trip, but that's not my question. My question is, that when I turned the breaker off to check the terminal connections on the outlet, I found out the circuit I had amped, was not the right one even though I did see the amperage go down before I took my amp meter off the wire, after the microwave had timed out. When I found the breaker that did control it, it was the "red" line of a multiwire circuit (12/3). I know I had my meter on the black wire of the 12/3, the first time. After checking the red wire, it had the same amperage as the black wire had. I checked the black wire again, and had no amperage. I AM getting old and am retired, but I do know what I did. Is there any theoretical explanation for this, maybe a loose neutral in the circuit, or am I just
"loosing it"? She has been living there 25 years, and this is the only time she can remember that the breaker tripped.
For my "sanity sake", hope someone has an answer
Thanks
Thanks
