If I have branch circuits utilizing A combination of EMT and MC cable wiring methods and I always specify the MC to have a separate ground conductor and my circuits all have a equipment grounding conductor, are all these circuits considered to have a isolated ground conductor ?
I guess the questions is if you use EMT is it always installed to qualify as a equipment ground or as a contractor would that change the way you install it if you you knew it needed it to be?
