I would greatly appreciate some input and see if someone can answer my questions on a house service that myself and another electrical engineer are designing and installing in Ohio (Current Code NFPA70 2017). I have a home and barn which are fed from a common utility pad mount transformer. There is 3 separate 200A disconnects to the house, each feeding a separate 200A panel, and one 200A disconnect for a 200A barn panel, fed parallel from an 800A utility service. Due to lead times and availability, the 4 disconnect option was the only means feasible for this installation to meet the deadline. Since the first means of disconnect is the service pedestal, the house neutral-ground bond and barn neutral-ground bond are at the pedestal in the disconnects. The service pedestal sits 100 feet from the house.
My questions:
My questions:
- Should the house and barn share or have separate ground rods? Are these ground rods adequate?
- Is this bonding correct?
- Should the 3 house panels all share the ufer ground ? Should only one tie into the ufer?
