jimport
- Outside Baltimore Maryland
- Master Electrician
This was from upcoming changes to the 2023 NEC. Thoughts on whether this means that pullout disconnects will now need to be locked? Or is the plastic shield enough?
To prevent a hazard from energized parts, Sec. 440.11 was revised to require disconnecting means with doors that can open to expose live parts to be lockable or require tools to open them when installed in areas readily accessible to unqualified persons.
No. 13 — Disconnects in Residential Spaces
