Hi. Installed an outside square permapost that holds a receptacle for someone about 4 years back.
I replaced the original WR GFCI installed receptacle a couple years back with another and now I just received a call that the newer one is not resetting.
It is tapped off the post light switched leg.
Besides the environment do you think turning it on and off everyday could cause it to prematurely fail ? Thank you.
