SamBowery
- Georgia, USA
- Control engineer.
Hi, my company does not have a copy of UL specifications so I am trying to glean some information on the web.
We have some small plc panels which use 24VDC to provide the control signals to run some lights, water valves, and a circulation fan.
The actual lights, and fans are fed separately for the power to run them, we simply send 0-10vdc to control speed, intensity. the water vales are 24VDC.
I find an awful lot of infor for machinery, and 3 phase motor circuits but nearly nothing on small applications like ours.
We have a small breaker inside the panle to protect the 24VDC power supplies, thats it. We feel this can be a supplimental protective device, and the breaker feeding the boxes from the building power would be the primary breaker. Supplimental protective devices are not rated as strictly under 508A, and are less expensive by quite a margin.
Ultimately the question is will the breaker from the building power panel suffice as the primary branch
circuit protection alllowing us to use the less expensive panle device inside the panlel.
Thank you in advance for any feedback. I am pressing our company to buy a copy of the UL508 standards but need an answer quickly on this particular application.
