- New Jersey
- Journeyman Electrician (retired)
After using dozens of wafer lights I don't think that I will even install cans again.
Good question. When I put a coffered ceiling in my family room I roughed the cables above the ceiling and then cut in the wafers in the exact center of each box. That was the only possible way to get the 16 lights centered in the boxes.Unless the customer just won't have anything but cans, I would go with the wafers.
How exactly do you adjust the joists?
Pros and Cons.Are you using genuine "can lights" or are you using the wafer thin recessed units?
Not worth the effort if using the wafer thin units.
slice/dice, x-frame, sister, hanger.Unless the customer just won't have anything but cans, I would go with the wafers.
I just IR'd one of my 4" 500lm 4K wafers. Ceiling is wide open to attic space (no insulation). Light face side clocks in at 104F.The heat issue is with dissipating enough heat to protect the LED's from overheat damage, they likely don't get anywhere hot enough to be an issue for possible combustion of the framing member in question, unlike the heat given off in conventional incandescent lamp type luminaires.
These wafer thin luminaires get a little warm to the touch but not enough you can't stand to touch them like some old luminaires could be.
For giggles, temp'd backside of my 6" BR40 4K 1400lm led in a sealed can. Clocked in at 140.2F
Spring wafers may not work if design size and lumens can't be had. Example, I not finding any 6" wafers that put out 1400lm and are thinner than 1/2 drywall.
The box of LED's says "17W, 100W equivalent"Since a 75W incandescent (normal max in a standard 6” can) will put out about 700lm, that should be the benchmark. Your 1400lm LED is a 150W incandescent equivalent.
