Grouch
- New York, NY
What is the current version of NFPA 780 (Standard for the Installation of Lightning Protection Systems) followed by NYC? I am not able to find it.
Thanks!
Thanks!
Thats not what I meant. I know the 2023 version is out. I'm asking, what VERSION is NYC following.NFPA 780, Standard for the Installation of Lightning Protection Systems
Get NFPA 780 for requirements on lightning protection system design, installation, and maintenance.catalog.nfpa.org
That's what I'm trying to find out and research.Doee NYC actually have any official requirements for lightning protection and have they adopted this standard?
aah. Soooo... if one chooses to install a lightning protection system, I'm assuming you can follow the 2023 version?NYC Building Code Chapter 35 has all referenced standards, and NFPA 780 is not listed.
CHAPTER 35 REFERENCED STANDARDS - 2020 BUILDING CODE OF NEW YORK STATE
ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.codes.iccsafe.org
Because it's NYC. Why do they use 2008 NEC with amendments while the state uses 2017? They kind of make the rules work for what they want.why wouldn't NYC follow this standard? I looked out the window... we have a lot of tall buildings!
In NYC we also don't have to file electrical drawings, except for services over 1000 kva.Because it's NYC. Why do they use 2008 NEC with amendments while the state uses 2017? They kind of make the rules work for what they want.
