inspector B
- sacramento
- inspector
my electricians are contesting the requirement to secure embedded items in concrete, to prevent movement, is there a code section to refer to ?
You're correct. I've seen 4" PVC float right to the top of the pour when it wasn't secured properly.depending on what type of raceway they use, it could float in the concrete and end up at the surface of the slab.
That be a site to see and feel bad for whoever is fixing thstYou're correct. I've seen 4" PVC float right to the top of the pour when it wasn't secured properly.
