Motoarrow51
- Nashville TN
- Journeyman Electrician/ LLE
I have always been taught that the GEC should not be spliced and should be continuous. I was recently told by an inspector to splice the GEC between ground rods. For example hit the first ground rod, cut the wire then run another wire from the first ground rod to the second. As I was taught that GEC should not be spliced at all. For example I always have had a continuous GEC from service to the first grounding electrode and continuous to the second grounding electrode. Is it ok to cut the wire and have it not continuous between the two grounding electrodes?
