tonype
- New Jersey
It was hard to see up into the hood area.Can't tell from the pic, but I don't see any clamps to secure the NM cable.
The wires are right above the filters.Is that that factory hole for the NM cable, or did they drill it in the wrong spot?
Looks like they pulled the wires down into the hood area.
Most the time there is no wiring there without needing to remove additional access panels, or is factory installed wiring and isn't just in free space but rather is neatly routed and secured as it passes through that space. I have never seen main supply wiring intended to be in this space.The wires are right above the filters.
