Greg H
- Durham, NC, USA
- Electrician
Hey all, I have a customer that recently bought an older house and they are worried that there may be some problems with the old wiring. The only specific things they mentioned are that the house has cloth insulated wiring that might be either aluminum or tinned copper. I didn't ask if it was knob and tube wiring as I didn't get the impression they would be able to tell. Long story short, I agreed to charge them $100 for an electrical inspection as well as to answer some of their questions about some possible future upgrades.
My plan for the inspection is to look inside the MSP and and any subpanels looking for any obvious problems (double terminated breakers, damaged wire, incorrect bonding etc.) as well as to scratch test any silver colored wiring to determine if it is aluminum and tinned copper. I'm going to look inside any readily accessible parts of the attic and/or crawlspace to see if there are any visible problems with the wire runs focusing especially on any runs of older cloth-sheathed NM cable for signs of fraying or cracking or if there is any knob and tube wiring, and to use a plug tester to test all readily accessible receptacles for correct grounding, etc. as well as pick maybe 1-3 receptacles at random to actually open up and check for any kinds of improper wiring.
Obviously, once I see it, there may or may not be a little or a lot that needs fixing, but my question was if any of y'all had had similar types of inspection type jobs, if you think $100 is a fair price for this, where/what you looked at/for, what kinds of problems you've found, anything else you recommend I make a point to take a look at, or just general advice for these kind of jobs. Thanks
