- NE Nebraska
- EC
Then this would be cutting corners wouldn't it?It is just me, because I am a permit nut.
I have always felt that cutting corners exposes yourself to liability.
Nothing to ask an AHJ about. The "guts" is the panel. The panel is listed. As long as you are not modifying the panel you're good. The housing/can is not part of the panel. As long as you fit the panel in properly, along with the cover, it's perfectly legal. I've done several retrofits and all passed inspection.I would ask the AHJ if it was acceptable. Back in the early 1970's I worked at a large slaughterhouse that had a couple of two phase panels built into walls that only feed 120 volt loads. We purchased two single phase panels and mounted the interiors then trimmed covers and had them welded onto original front panel.
NEC calls the housing or can a "cabinet"I would ask the AHJ if it was acceptable. Back in the early 1970's I worked at a large slaughterhouse that had a couple of two phase panels built into walls that only feed 120 volt loads. We purchased two single phase panels and mounted the interiors then trimmed covers and had them welded onto original front panel.
My state does not have state license for electricians and some small town guy that is the king of the hill with not only being the only electrical contractor in town but issues electrical license then after you have your approved inspection agency come out & pass jobs they come along and fail the job because like two told me they have their own codes so found it cheaper & faster to pass things by them before work is started. Had one hick type fail me because I spliced one #14 guage wire in a panel. Told him what NEC article allowed this and he told me that " I will let you get away with it this time".Nothing to ask an AHJ about. The "guts" is the panel. The panel is listed. As long as you are not modifying the panel you're good. The housing/can is not part of the panel. As long as you fit the panel in properly, along with the cover, it's perfectly legal. I've done several retrofits and all passed inspection.
