Are you going to have a blank metal cover to provide access?In a return air cavity ( stud space with drywall on each side) is it allowable to use a metal rework box and metal cable in that space?
It is going to be a wall switch for the room lighting.Are you going to have a blank metal cover to provide access?
I might consider a surface mounted box. But I don't guess it matters it's just the return so it should not have a temperature change to cause sweat.It is going to be a wall switch for the room lighting.
There is a double stud space ( approximately 30” wide) of return air just to the right of the door opening.
To totally avoid that space my wall switch will be almost 3’ away from where you enter the room.
It’s a new addition in a rather nice home.I might consider a surface mounted box. But I don't guess it matters it's just the return so it should not have a temperature change to cause sweat.
I would just put it in the return and wouldn't use NM cable.It’s a new addition in a rather nice home.
I doubt the owner will accept a surface mount device in their new master suite.
I guess 3’ away is where it will go.
It’s allowable with a metal box and MC cable?I would just put it in the return and wouldn't use NM cable.
Great idea.If location of switch is a problem Put it in some inconspicuous spot and install a Lutron Pico controller and remote. Put the remote were your having your difficulty.
That is exactly what I was going to say. We do that frequently when rooms have double pocket doors.If location of switch is a problem Put it in some inconspicuous spot and install a Lutron Pico controller and remote. Put the remote were your having your difficulty.
Yes.It’s allowable with a metal box and MC cable?
Even running the cable parallel with the studding up through the top plate?
