Q1: Say you had an industrial plant that was fed from a detla wye ungrounded system. If you grounded the Xo terminal on the transformer secondary, but didn't send the neutral conductor to the service equipment, would there be any benefit such as mitigating overvoltages? Would the building system still be classified as ungrounded?
Q2: Furthering the discussion say you carried the neutral to the service equipment and set up a grounding electrode system. If you only fed your downstream panels with three phase conductors and no neutral would this qualify as ungrounded? If someone touched one of the phase conductors would it act like a grounded system?
