rojay
- Chicago,IL USA
I had to install a load management module for a customer’s 50 amp, 220 volt oven as part of a recent generator install. The panel was in a finished basement, so I used 3/4”FMC for the 4-#8’s running between the panel & the equipment. I also added a #10 EGC to the whip, purely out of my habit of adding one to every whip I install.
My question is- since the load management module is plastic, was the EGC necessary? I ended up connecting the ground to a grounding bushing at the module end.
