The utility is not subject to the NEC.1) Are these conductors installed under the NESC (POCO standards, used for things such as service drops) or NEC (National Electrical Code, used for building wiring)?
-Jon
Any rules from the NESC would apply.
-Jon
The ACSR does not encircle the covered conductors so it will not have an inductive heating effect. There will be some minor inductive coupling, but if the ACSR is bonded it won't be an issue.But that grounding conductor in the PVC raceway probably won't have the steel strand the ACSR has, so magnetic effects are going to be different.
The conductors encircle it though. This is the basis of how motor, transformer and solenoid windings and cores are designed. It probably produces some heat at the very least even if there is little other significant effects.The ACSR does not encircle the covered conductors so it will not have an inductive heating effect. There will be some minor inductive coupling, but if the ACSR is bonded it won't be an issue.
