Having issues I have a three phase 208 service each leg is 120 V to ground no high leg, and I have two hot water heaters ran in tandem one hot water heater, feeds water into the Herzing winery, the issue I’m having is one water heater keeps blowing the fuse on the B phase all voltage is within reason 125 V per leg on 230 V rated fuses and I have proper continuity where it needs to be across those heating elements. I have no continuity between phasing ground everything checks out fine and as soon as I hook up the bee phase. It immediately burns the fuse within 1 ms.
