Isaiah
- Baton Rouge
- Electrical Inspector
I have a three phase 120/208V 4W panelboard that sub feeds another 3-ph Panelboard - MLO-located about 20’ away in the same building.
The first panelboard has a GEC at the 45kVA transformer mounted directly above it.
The second panelboard does not have a GEC nor are the neutral bus and ground bus bonded together. Also field did not run the neutral to the sub panel.
