M Mike410is Member Location Florida Occupation Residential electrician Feb 15, 2023 #1 I have a 200amp exterior panel with feed-through lugs that feeds a 150amp sub-panel inside the house. Do I need to size my feeder conductors to the 200amp even though my sub-panel has a 150amp main breaker?
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Feb 15, 2023 #2 Yes, unless you can use one of the tap rules.
M Mike410is Member Location Florida Occupation Residential electrician Feb 15, 2023 #3 LarryFine said: Yes, unless you can use one of the tap rules. Click to expand... Thanks
