Newly installed 480/277 3ph pad mounted generator at an industrial site. There will be no neutral used just a 3ph 480 motor. The generator EGC is connected to a cable tray 4/0 bare ground running in the cable tray.The neutral is not bonded to the EGC . Is a ground rod required here ?
