zemingduan
- Philadelphia,PA
- Electrical Designer
Hi I was always thinking 1200A circuit breaker will need the arc energy reduction per NEC 240.87. But when I read the code today, I found the code language is "Where the highest continuous current trip setting for which the actual overcurrent device installed in a circuit breaker is rated or can be adjusted is 1200 A or higher,..." I am wondering most typical 1200A circuit breaker used for residential meter bank (supply the apartment units) main is 80% rated and doesn't need to be 100% rated. Does these typical 1200A circuit breakers above even have/need continuous current trip setting? So do they still need Arc reduction?
