DISCONNECTWhat type of control are they on now... magnetic starter, breaker, disconnect ??
It's for trash compactors. The owner doesn't want to provide a larger panel so they want to be able to lock out one motor so the load doesn't impact the panel for both motors.Much more information is needed. Are you looking to automatically switch loads, and if so, based on what criteria? Are you just looking to use the load calculation for non concurrent loads? Or a way to strictly prevent one motor from running when the other is, etc?
kind of a loaded question. it is not especially difficult to do what you asked but the simpler solutions might not be suitable.I have two motors on a circuit but would like to only run one at a time. What type of controls would I need to lock out one while the other is running?
I don't think a typical disconnect switch is suitable for use as a motor controller at all.DISCONNECT
Post a wiring diagram.It's for trash compactors. The owner doesn't want to provide a larger panel so they want to be able to lock out one motor so the load doesn't impact the panel for both motors.
We don't have any idea how big these motors are at the moment.I don't think a typical disconnect switch is suitable for use as a motor controller at all.
would not matter any. a typical disconnect switch is not suitable for use a a motor controller.We don't have any idea how big these motors are at the moment.
Most of the time when the term "disconnect" is used, we are really talking about a "safety switch" and most of those are horsepower rated making them suitable for use as a motor controller.I don't think a typical disconnect switch is suitable for use as a motor controller at all.
