ZSIM
 - United States
 - Electrical Engineer
Looking to learn, what is the maximum length of aircraft cable you would use to install a light fixture to suspend from a ceiling?   So  that it wouldn’t cause swing from say a dock door opening and wind coming in.
I have a small installation where the plans call for a few lithonia IBG to be installed in a portion of a 40 ft warehouse. The plans suggest installing the lights at 25 feet above finish floor. That would basically be 15 feet of aircraft cable.
I was always under the impression that would be too long to suspend a luminaire for a couple reasons, but in this case because they would probably swing.
Lithonia does offer though a 20 foot aircraft cable wire for suspension, so it does seem like it’s commercially viable.
So just looking for people’s thoughts on if they should be raised up with a higher lumen package, or if this is common / acceptable installation?
Any pitfalls to watch out for if I do suspend them 15 feet down?
