blueheels2
- Raleigh, NC
- Electrical contractor
I wired a residential remodel last summer, and in the process I upgraded the service to 400 amps. I installed meter outsid with 200 amp disconnects beside it and then on the interior there are 2-200 amp panels.
Customer reached out about a month ago and said he had a couple of tv’s go bad, also his car charger started malfunctioning. The WiFI portion went out at Christmas and in the past month the charger gets a red light and says it’s overheating. In the process of troubleshooting I realized I messed up and pulled 6NM-B to the charger, it’s a 48A charger. So I’m going to repull in MC next week.
When he called back in early February I went out and verified all of my connections were tight in the service and panel. No’s issues I could tell and no signs of overheating on the charger wire. And while I understand the NM-B is wrong I don’t think that’s what the issue is. Also while there I went through and turned on every load I could think of hear dryer lights oven etc to put the biggest load on the service I could. But no flickering or problems while I was there.
Customer reached out yesterday and said he was cooking with his Sous vide Monday and it quit working mid cycle and is a brick now.
I called the power company and they are going out for a line check today but neighbors aren’t having issues and the transformer feeds. 3-4 houses I believe (engineer told me this on site visit to discuss upgrade). So at this point I think it’s the line to the house or something in the service.
If they don’t find anything today the only thing I know to do is put a power quality meter on the service for a month. I assume I would just hook up to one panel and it will sense if their are surges or neutral loss coming from the source? I was going to rent one. If a meter is hooked up for 2 weeks and a problem occurs on a random day will the meter capture the issue and store it? Is it in sleep mode until an issue arises. If something happens really fast 2 weeks in will it capture it?
Any other suggestions.
