cbooker
- Dallas, TX
- Electrical Contractor
So my electrician got red tagged today, and 1 of the reasons was the inspector stated the bare copper #6 EGC going to the Ground Rod is suppose to be terminated at the neutral bus on the Transfer Switch. Inspector stated that this is a new requirement in the Code. The transfer switch's Neutral is Bonded to Ground inside the switch so technically no big deal. However, it still doesn't sound right to Terminate the EGC at neutral bus and not on the actual Ground Bus inside the Switch. The "new code" the inspector is referencing sounds a bit strange to me if that truly is a new Code Requirement. Anybody here ever heard of the new code requirement for Terminating EGC at Neutral Bus for 1st means of disconnect on a single family residential dwelling?
