Hello all, I had an employee point out this code reference:
220.82 (C) 3 - 100 percent of the nameplate rating(s) of the heat pump compressor and 65 percent of the supplemental electric heating for central electric space-heating systems. If the heat pump compressor is prevented from operating at the same time as the supplementary heat, it does not need to be added to the supplementary heat for the total central space-heating load.
I have always calculated the load for a heat pump system based on the heat strips only. Should I be including both the heat pump motor and electric heat strips in the load calculation?
Thanks
Joe
Thanks
Joe
