Ole electric
- MetroWest Boston
like this little fellow?
Didn't most places that may have still had that kind of gear send their production operations to Mexico or China? Where they probably used more modern gear but still gear that wouldn't be listed for use here?I’m not sure any of us are that old…
I’ve only seen that sort of stuff in the process of replacing it. From a modern standpoint, I don’t think there is an OSHA compliant way to operate that without assuming the worst in terms of arc flash ratings, so a full 40cal suit up.
What is that laying there???like this little fellow?
Looks like a rag nobody dared to reach over and remove.What is that laying there???
Looks like a rag nobody dared to reach over and remove.![]()
8'How high off the floor is that buss?
safe enough for the properly trainedThe open 600 volt DC swithboard on the retired NYFD fire boat "Firefighter". This was in service with the NYFD from 1938 to 2010, and the boat is still functional as a museum ship. Two 16 cylinder 1,500 hp diesel engines turned a total of six 600 volt DC generators with a total output of 2200 kW. The switchboard was used to channel power to the propulsion motors and/or the four 5000 GPM fire pump motors.
maybe a large rodentWhat is that laying there???
Sounds like there's a fairly funky assortment of mechanical drive components in there, unless maybe they're all lined up in a row, lineshaft style.... Two engines ... six generators ...
An inline set up with each of the generators having shafts on each end...all coupled together. Out of the 16 cylinder diesel to the largest generator, then coupled to the next one, and then to the smallest generator on the end. I don't remember the generator ratings, but pretty sure the largest one was 900 kW. The switchboard let them send power to the 4 fire pumps and/or the propulsion motors.Sounds like there's a fairly funky assortment of mechanical drive components in there, unless maybe they're all lined up in a row, lineshaft style.
I would sure hate to be anywhere near that switchboard in heavy seas.
