dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
Would an existing panel be code compliant in a bathroom if the door opens on the outside of the bathroom?
Sounds like a gray area on a residential bathroom. It must be pretty close to outside the bath. Do you have a pic?Would an existing panel be code compliant in a bathroom if the door opens on the outside of the bathroom?
I thought if the door opened toward another room it would no longer be considered in a bathroom.It's okay in commercial not residential
Yes the panel doorWhat door the panel door?
I agree but, if you have to ask it must be in the bath ,I thought if the door opened toward another room it would no longer be considered in a bathroom.
Then it's not in the bathroom, just within a bathroom wall, which is okay.Yes the panel door
Huh? That doesn't make a lick of senseThen it's not in the bathroom, just within a bathroom wall, which is okay.
Makes perfect sense to meHuh? That doesn't make a lick of sense
The description is that there is a panel in a bathroom, but its door opens outside the bathroom.Huh? That doesn't make a lick of sense
Then the panel is not in the bathroom.Thus, I conclude that the back of the panel is toward the bathroom, so it's in the bathroom wall.
Panel door would open into another roomSounds like a gray area on a residential bathroom. It must be pretty close to outside the bath. Do you have a pic?
You know, It's okay in commercial not residential
Yea I prefer how you stated it better. Yes a shared wallThere's a lot better way of stating this than "door opens toward another room", that's confusing. Just say it's in a xx room wall that shares a wall with the bathroom. Sharing a wall is not the same as being in a room. You could say a panel is outside but door opens to the inside, doesn't make sense.
The panel is not in the bathroom.
Correct shared partition wall back of panel towards bathroom but covered with dry wallThe description is that there is a panel in a bathroom, but its door opens outside the bathroom.
Semantics…Correct shared partition wall back of panel towards bathroom but covered with dry wall
Looked to me that he said the panel is in the bathroom, but the panel door opens outside the bathroom.The description is that there is a panel in a bathroom, but its door opens outside the bathroom.
