timm333
- Minneapolis, MN
- Electrical Design Engineer
I have a question about hazardous area classification for battery room. NEC 500.6(A)(2) states that the areas which have hydrogen (batteries) shall be classified as Class I Group B. However hydrogen has a high flash point (1058 Deg F) and that much temperature is not possible in battery room. Because as per NEC Table 500.8(C), the maximum possible temperature of electrical equipment is for T1 type enclosure which is only 842 Deg F.
As 842 Deg F is less than 1058 Deg F, so I think hydrogen (battery room) should not be required to be classified. What do you guys think about it? Thanks
