Alwayslearningelec
- NJ
- Estimator
When installing receptacles in millwork I know the carpenter would cut the opening.
Two questions:
1. When installing the box is it more difficult( than standard mounting on metal stud) and is a special box required?
2. When running the branch MC cable is it more difficult to install then say running in an open wall through studs?
3. Would the electrician do any cutting for the MC cable entry/exit out of the millwork from the wall?
Thank you.
Two questions:
Thank you.
