PWDickerson
- Clinton, WA
- Solar Contractor
When I started as a PV designer 12 years ago, I remember that there was a code requirement that, in the case where the inverter and the solar array were located in/on separate structures, a DC disconnect was required at the building with the solar array. I remember that code section being not so easy to find, and I suspect that it disappeared when rapid shutdown was invented. But I would sure like to confirm that. I have looked back through my 2008 and 2011 code books, and I can't find that older requirement. Does anybody else remember that? Can you point me to the code section?
