gas furnace requires a switch ?
Stevenfyeager
United States, Indiana
electrical contractor
Customer wants me to just put a cord and plug on his renter's gas furnace and plug it into a nearby outlet. I've always (and hvac guys too) put a switch on the furnace, wired from above in conduit. NEC rules on this ? Thanks.
I think an appliance is supposed to be listed for cord-and-plug connection to do that.
But I've done it for someone who wanted to be able to plug it into a generator during a power outage
Wouldn't that be a case of using a cord in place of permanent wiring, especially since furnaces are stationary?
I don't think I've ever seen a residential furnace fastened in place. Just placed on the floor, with nothing more than gravity and friction as the "fastening means".
But I also haven't worked in any jurisdiction with seismic codes.
How about the ductwork and gas line? There is no way that you could consider a furnace not fastened in place.
I've heard this one before. In parts of the country, it's common for the HVAC equipment to be wired with a cord and plug. I have no idea why except that it was probably wired by the HVAC installer because he didn't know any better. Ridiculous!
-Hal
How about the ductwork and gas line? There is no way that you could consider a furnace not fastened in place. ...
Just playing the Devil's Advocate today. Is it "fastened in place" if it's just sitting there? I honestly can't say. Potato, potatoe.
... HVAC equipment to be wired with a cord and plug. I have no idea why ...
C&P would facilitate safely using a portable standby generator without installing a formal transfer switch, and reduce the incentive for guys like my dad to cobble together a dryer cord.
A good compromise would be hard-wiring in a single-item transfer switch like one O'Deeze:
Less invasive and less costly than a whole-house transfer switch; satisfies everybody who insists on permanent hard wiring.
I have seen disposals hardwired with MC. (and probably also BX) I think it's common in Chicago, where they require metal conduit for just about everything.
I've seen BX a bunch in 20s to 60s houses. After that, hardwired with Romex.
But rarely see a hardwired disposal from the 90s on
I think there is some other mechanical code or maybe IRC or IBC that requires a shutoff switch for a furnace that has to be somewhere out of the immediate vicinity of the furnace. I can't find where that requirement comes from--maybe they've done away with it or it's only for oil furnaces?
No. The I-codes refer to the electrical code as far as electrical requirements are concerned.
Ron
