- New Jersey
- Journeyman Electrician (retired)
Is anyone who is under the 2023 NEC using 10 amp lighting circuits with #14 copper clad aluminum wire?
Copper weld makes it.Does anyone make #14 CCA building wire?
Does anyone make connectors listed for CCA building wire?
Does anyone make 10 amp AFCI breakers (dwelling use)?
The smallest size I see on their web site is #12.Copper weld makes it.
I got some at my shop. Did not price out any different than copper.
Less cost in materials vs more in labor cause of box fill and pig tailing all 10-2 copper clad to 12-2 copper for devices was a pain. Not worth it.
While it does for wiring devices it does not for wire connectors per the listings.In theory, it seems the copper cladding should make it compatible with CU-rated splices and terminations.
So whenever you need to splice them, just install a receptacle. : - )While it does for wiring devices it does not for wire connectors per the listings.
